Api session event editor panel remove answer
Revision as of 07:54, 31 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Answer (Panel)
0 REQUIRED (PANEL Integer ID or multiple values in array [1, 2, 3]) Panel
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/remove_answer/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]
