Api session event editor netload import
API Event to Import multiple Net Loads
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | GeometryCollection | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 2 | REQUIRED | (NetType or multiple values in array [a, b, c]) | NetType[] | |
| 3 | REQUIRED | (TimeState or multiple values in array [a, b, c]) | TimeState[] | |
| 4 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 5 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 6 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | double[][] | |
| 7 | REQUIRED | (Integer number) | Integer | |
| 8 | REQUIRED | (Floating point number) | Double | |
| 9 | REQUIRED | (Floating point number) | Double | |
| 10 | REQUIRED | (SOURCE Integer ID) | Source |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editornetload/import/?crs=3857&f=HTML&token=API_TOKEN
with content:
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799407.673230342 ], [ 658798.5274306147, 6799407.673230342 ], [ 658798.5274306147, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799394.94334692 ], [ 658676.4411204401, 6799394.94334692 ], [ 658676.4411204401, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799366.794101927 ], [ 658650.6449668616, 6799366.794101927 ], [ 658650.6449668616, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Text 1", "Text 2", "Text 3" ], [ "INTERNET", "ELECTRICITY", "HEAT" ], [ "WAITING_FOR_DEMOLISH_DATE", "DEMOLISH_DENIED", "PENDING_UPGRADE" ], [ "Text 1", "Text 2", "Text 3" ], [ "Text 1", "Text 2", "Text 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], 25, 18, 46, 58 ]
