Api session event editor measure set cost
Revision as of 07:51, 31 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set the Cost of a Measure of a particular Cost type (construction, demolition) and wether it is fixed or Cost per cubic meter.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Enumeration) Cost Type CONSTRUCTION
2 REQUIRED (Floating point number) Cost in valuata
3 REQUIRED (true, false) Fixed (if false, Cost per cubic meter) true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_cost/?f=HTML&token=API_TOKEN
with content:
[ 78, "CONSTRUCTION", 56, true ]
