Api session event editor indicator set attributes
API Event to Set multiple Indicator attribute values
| 0 | REQUIRED | (INDICATOR Integer ID or multiple values in array [1, 2, 3]) | Indicator | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute Names | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | Attribute Values | |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_attributes/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], "" ]
