Api session event editor area generate sewer areas
Revision as of 07:49, 31 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Generate Sewer Area
0 REQUIRED (Integer number) Integer
1 REQUIRED (Floating point number) Double
2 REQUIRED (Floating point number) Double
3 REQUIRED (Floating point number) Double
4 REQUIRED (String) String
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/?f=HTML&token=API_TOKEN
with content:
[ 44, 10, 74, 67, "Text" ]
