Api session event editor weather remove
Revision as of 14:17, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove the specified Weathers.
0 REQUIRED (WEATHER Integer ID or multiple values in array [1, 2, 3]) Weather IDs
Example POST: https://engine.tygron.com/api/session/event/editorweather/remove/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
