Api session event editor measure remove terrain polygons
Revision as of 14:14, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove polygons from existing outer (or inner) polygons of a Terrain Spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) Terrain Spatial ID
2 REQUIRED (true, false) Is Outer (false = inner) true or false
3 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/remove_terrain_polygons/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ 18, 74, true, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799335.70044146 ], [ 658789.3900409506, 6799335.70044146 ], [ 658789.3900409506, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
