Api session event editor indicator set target
Revision as of 14:13, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set a target value of an Indicator for a Sceanrio. A target index value is required.
0 REQUIRED (SCENARIO Integer ID) Scenario ID
1 REQUIRED (INDICATOR Integer ID) Indicator ID
2 REQUIRED (Integer number) Target index
3 REQUIRED (Floating point number) Target value
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_target/?f=HTML&token=API_TOKEN
with content:
[ 90, 41, 59, 30 ]
