Api session event editor cinematic add keypoint with parameters
Revision as of 14:11, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add Keypoint With Parameters
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Datas
1 REQUIRED (Integer number) Integer
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Float[]
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Float[]
4 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Float[]
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/?f=HTML&token=API_TOKEN
with content:
[ 74, 62, [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ] ]
