Api session event editor area set active
Revision as of 14:10, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Area active
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Areas
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Boolean[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorarea/set_active/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ] ]
