Api session event editor measure remove event
Revision as of 13:54, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add a specific event of a Measure for a specific Action Type.
0 REQUIRED (MEASURE Integer ID or multiple values in array [1, 2, 3]) Measure ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Server Side (false = Client Side)
2 REQUIRED (ActionType or multiple values in array [a, b, c]) Action Type
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Event ID
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/remove_event/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ], [ "CONSTRUCTION_PLAN_CANCEL", "CONSTRUCTION_PLAN_CANCEL", "CONSTRUCTION_PLAN_CANCEL" ], [ 1, 2, 3 ] ]
