Api session event editor weather remove flood overlay
Revision as of 10:27, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove the specified visualization overlay from specified weather. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(WEATHER Integer ID or multiple values in array [1, 2, 3]) |Weather ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorweather/remove_flood_overlay/?f=H...")
0 REQUIRED (WEATHER Integer ID or multiple values in array [1, 2, 3]) Weather ID
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorweather/remove_flood_overlay/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
