Api session event editor weather set name
Revision as of 10:27, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set the name for a specified weather. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(WEATHER Integer ID or multiple values in array [1, 2, 3]) |Weather ID | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Name for the weather | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tyg...")
0 REQUIRED (WEATHER Integer ID or multiple values in array [1, 2, 3]) Weather ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Name for the weather
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorweather/set_name/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Name for the weather 1", "Name for the weather 2", "Name for the weather 3" ] ]
