Api session event editor unitdataoverride set active
API Event to Set Unitdataoverride active
| 0 | REQUIRED | (UNIT_DATA_OVERRIDE Integer ID or multiple values in array [1, 2, 3]) | [[Unit Data Override]]s | |
| 1 | REQUIRED | (Boolean or multiple values in array [true, false, true]) | Boolean[] |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorunitdataoverride/set_active/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ] ]
