Api session event editor trigger add
Revision as of 10:25, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add new Trigger {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |OPTIONAL |(Timing or multiple values in array [a, b, c]) |Timing[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer[] (Integer array) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editortrigger/add/?f=HTML&token=API_TOKEN with content: <pre>[ "" ] </pre> {{article en...")
0 OPTIONAL (Timing or multiple values in array [a, b, c]) Timing[]
200 Integer[] (Integer array)
with content:
