Api session event editor stakeholder set start budget
Revision as of 10:25, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Start Budget {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholders | |- |1 |REQUIRED |(Floating point number) |Double | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/?f=HTML&token=API_TOKEN with conte...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
1 REQUIRED (Floating point number) Double
204 No Content
with content:
[ 3, 49 ]
