Api session event editor source add catalog
Revision as of 10:23, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add Catalog {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(Enumeration) |GeoCatalog |CSW or ESRI |- |1 |REQUIRED |(String) |String | |- |2 |REQUIRED |(String) |String | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Integer) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorsource/add_catalog/?f=HTML&token=API_TOKEN w...")
0 REQUIRED (Enumeration) GeoCatalog CSW or ESRI
1 REQUIRED (String) String
2 REQUIRED (String) String
200 Integer (Integer)
with content:
[ "CSW", "Text", "Text" ]
