Api session event editor sound remove
Revision as of 10:23, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove existing Sound {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(SOUND Integer ID or multiple values in array [1, 2, 3]) |Sounds | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Boolean (True when at least one item was removed) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorsound/remove/?f=HTML&token=API_TOKEN wit...")
0 REQUIRED (SOUND Integer ID or multiple values in array [1, 2, 3]) Sounds
with content:
[ [ 1, 2, 3 ] ]
