Api session event editor setting set default geoplugin
API Event to Set Default Geoplugin
| 0 | REQUIRED | (Enumeration) | MapLink | ACTION_LOGS, ACTION_MENUS, ADDRESSES, AREAS, ATTRIBUTE_ACTIONS, BUILDINGS, CHAT_MESSAGES, CINEMATIC_DATAS, CLIENT_WORDS, COSTS, CUSTOM_GEOMETRIES, DEFAULT_WORDS, ERROR_LOGS, EVENT_BUNDLES, EXCEL_SHEETS, FUNCTION_OVERRIDES, FUNCTIONS, GEO_LINKS, GEO_OPTIONS, GEO_PLUGINS, GEO_TIFFS, GLOBALS, HEIGHTS, INCOMES, INDICATORS, LEVEES, MEASUREMENTS, MEASURES, MODEL_DATAS, MODEL_SETS, MONEY_TRANSFERS, NEIGHBORHOODS, NET_CLUSTERS, NET_FUNCTIONS, NET_LINES, NET_LOADS, NET_NODES, NET_SETTINGS, NEURAL_NETWORKS, OVERLAYS, PANELS, PARAMETRIC_DESIGNS, PARAMETRIC_EXAMPLES, PARTICLE_EMITTERS, PLOTS, POPUPS, PROGRESS, PROJECT_ASSETS, RECORDINGS, SCENARIOS, SERVER_WORDS, SETTINGS, SOUNDS, SOURCES, SPECIAL_EFFECTS, SPECIAL_OPTIONS, STAKEHOLDERS, TERRAIN_TYPE_OVERRIDES, TERRAIN_TYPES, TERRAINS, TEXTURES, TIMES, TRIGGERS, UNIT_DATA_OVERRIDES, UNIT_DATAS, UPGRADE_TYPES, WATER_VALUES, WEATHERS, ZIP_CODES or ZONES |
| 1 | REQUIRED | (Integer number) | Integer |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorsetting/set_default_geoplugin/?f=HTML&token=API_TOKEN
with content:
[ "PARAMETRIC_DESIGNS", 56 ]
