Api session event editor setting get sun azimuth
Revision as of 10:22, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Get Sun Azimuth value for local time in this Project {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(Integer number) |Year | |- |1 |REQUIRED |(Integer number) |Month | |- |2 |REQUIRED |(Integer number) |Day | |- |3 |REQUIRED |(Integer number) |Hour | |- |4 |REQUIRED |(Integer number) |Minute | |- |5 |REQUIRED |(Integer number) |Second | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Double (Su...")
0 REQUIRED (Integer number) Year
1 REQUIRED (Integer number) Month
2 REQUIRED (Integer number) Day
3 REQUIRED (Integer number) Hour
4 REQUIRED (Integer number) Minute
5 REQUIRED (Integer number) Second
200 Double (Sun Azimuth value)
Example POST: https://engine.tygron.com/api/session/event/editorsetting/get_sun_azimuth/?f=HTML&token=API_TOKEN
with content:
[ 2013, 8, 2, 12, 0, 0 ]
