Api session event editor plot set owner
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Owner {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PLOT Integer ID) |Plots | |- |1 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholders | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorplot/set_owner/?f=HTML&token=API_TOKEN with content: <pre>[ 88, 2 ] </pr...")
0 REQUIRED (PLOT Integer ID) Plots
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
204 No Content
with content:
[ 88, 2 ]
