Api session event editor parametric set polygons
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Polygons {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) |Parametric Designs | |- |1 |REQUIRED |(MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) |MultiPolygon[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://eng...")
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) Parametric Designs
1 REQUIRED (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) MultiPolygon[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorparametric/set_polygons/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799382.926472285 ], [ 658645.8180343907, 6799382.926472285 ], [ 658645.8180343907, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799392.011806051 ], [ 658691.2434967995, 6799392.011806051 ], [ 658691.2434967995, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799430.333057039 ], [ 658731.8663887788, 6799430.333057039 ], [ 658731.8663887788, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
