Api session event editor parametric set plot function
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Plot Function {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) |Parametric Design | |- |1 |REQUIRED |(Integer number or multiple values in array [1, 2, 3]) |Plot | |- |2 |REQUIRED |(FUNCTION Integer ID or multiple values in array [1, 2, 3]) |Function | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Co...")
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) Parametric Design
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Plot
2 REQUIRED (FUNCTION Integer ID or multiple values in array [1, 2, 3]) Function
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorparametric/set_plot_function/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ 1, 2, 3 ] ]
