Api session event editor parametric set plot attributes
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Plot Attributes {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) |Parametric Design | |- |1 |REQUIRED |(Integer number or multiple values in array [1, 2, 3]) |Plot | |- |2 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Attribute name | |- |3 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0] or matri...")
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) Parametric Design
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Plot
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute name
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute Values
4 OPTIONAL (Integer number) Source (optional)
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorparametric/set_plot_attributes/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ "Attribute name 1", "Attribute name 2", "Attribute name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], "" ]
