Api session event editor parametric set function
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Function {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) |Parametric Designs | |- |1 |REQUIRED |(FunctionType or multiple values in array [a, b, c]) |FunctionType[] | |- |2 |REQUIRED |(Integer number or multiple values in array [1, 2, 3]) |Integer[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |-...")
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) Parametric Designs
1 REQUIRED (FunctionType or multiple values in array [a, b, c]) FunctionType[]
2 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorparametric/set_function/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "PARKING", "BUILDING", "SIDEWALK" ], [ 1, 2, 3 ] ]
