Api session event editor parametric set alignment
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Alignment {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) |Parametric Designs | |- |1 |REQUIRED |(Alignment or multiple values in array [a, b, c]) |Alignment[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/sessio...")
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) Parametric Designs
1 REQUIRED (Alignment or multiple values in array [a, b, c]) Alignment[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorparametric/set_alignment/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "SPACED", "ROAD", "SPACED" ] ]
