Api session event editor parametric save as measure
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Save As Measure {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PARAMETRIC_DESIGN Integer ID) |Parametric Designs | |- |1 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholders | |- |2 |REQUIRED |(FunctionType or multiple values in array [a, b, c]) |FunctionType[] | |- |3 |REQUIRED |(Integer number or multiple values in array [1, 2, 3]) |Integer[] | |- |4 |REQUIRED |(MultiPolygon or multiple values in array [a, b,...")
0 REQUIRED (PARAMETRIC_DESIGN Integer ID) Parametric Designs
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
2 REQUIRED (FunctionType or multiple values in array [a, b, c]) FunctionType[]
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
4 REQUIRED (MultiPolygon or multiple values in array [a, b, c]) MultiPolygon[][]
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorparametric/save_as_measure/?f=HTML&token=API_TOKEN
with content:
[ 12, 80, [ "GARDEN", "REMAINDER", "SIDEWALK" ], [ 1, 2, 3 ], [ [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799418.663693125 ], [ 658661.3902512584, 6799418.663693125 ], [ 658661.3902512584, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799318.184425726 ], [ 658641.5075771975, 6799318.184425726 ], [ 658641.5075771975, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799455.8286861805 ], [ 658733.8121038192, 6799455.8286861805 ], [ 658733.8121038192, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799317.021565011 ], [ 658646.2939062661, 6799317.021565011 ], [ 658646.2939062661, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799332.653610224 ], [ 658723.7132255876, 6799332.653610224 ], [ 658723.7132255876, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799339.499237451 ], [ 658791.8083795944, 6799339.499237451 ], [ 658791.8083795944, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
