Api session event editor parametric generate
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Generate {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PARAMETRIC_DESIGN Integer ID) |Parametric Designs | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |PDResult (PDResult) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorparametric/generate/?f=HTML&token=API_TOKEN with content: <pre>[ 83 ] </pre> {{article end|seealso=*...")
0 REQUIRED (PARAMETRIC_DESIGN Integer ID) Parametric Designs
200 PDResult (PDResult)
with content:
[ 83 ]
