Api session event editor panel remove answer
Revision as of 10:19, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove Answer {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PANEL Integer ID or multiple values in array [1, 2, 3]) |Panels | |- |1 |REQUIRED |(Integer number or multiple values in array [1, 2, 3]) |Integer[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorpanel/r...")
0 REQUIRED (PANEL Integer ID or multiple values in array [1, 2, 3]) Panels
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/remove_answer/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]
