Api session event editor panel add overlay template
Revision as of 10:19, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add Overlay Template {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(Enumeration) |PanelTemplate |DANGEROUS_OBJECTS, NETWORK_INTERACTION, TRAFFIC_NOISE, WATER_AREAS or WEIRS |- |1 |REQUIRED |(OVERLAY Integer ID) |Overlays | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Integer) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api...")
0 REQUIRED (Enumeration) PanelTemplate DANGEROUS_OBJECTS, NETWORK_INTERACTION, TRAFFIC_NOISE, WATER_AREAS or WEIRS
1 REQUIRED (OVERLAY Integer ID) Overlays
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorpanel/add_overlay_template/?f=HTML&token=API_TOKEN
with content:
[ "WATER_AREAS", 45 ]
