Api session event editor overlay set show system visualization
Revision as of 10:18, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set whether a specified Overlay visualizes the graph of systems which dictates its calculation. Pipes, center points of areas, etc. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID) |Overlay ID (must relate to a water Overlay) | |- |1 |REQUIRED |(Enumeration) |Visual Type |AREAS or OBJECTS |- |2 |REQUIRED |(true, false) |Show |true or false |} ===Response Codes=== {|class=wikitable !Response Code...")
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a water Overlay)
1 REQUIRED (Enumeration) Visual Type AREAS or OBJECTS
2 REQUIRED (true, false) Show true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/?f=HTML&token=API_TOKEN
with content:
[ 57, "OBJECTS", false ]
