Api session event editor overlay set rasterization
Revision as of 10:18, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set the type of rasterization a specified AVG or Distance Overlay should do. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID) |Overlay ID (must relate to an AVG or Distance Overlay) | |- |1 |REQUIRED |(Enumeration) |Rasterization type: FIRST, MIN, MAX, SINGLE_LAYER, GRID |FIRST, MAX, MIN, SINGLE_LAYER or GRID |- |2 |OPTIONAL |(Enumeration) |MapLink (will only affect the SINGLE_LAYER rasterization...")
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to an AVG or Distance Overlay)
1 REQUIRED (Enumeration) Rasterization type: FIRST, MIN, MAX, SINGLE_LAYER, GRID FIRST, MAX, MIN, SINGLE_LAYER or GRID
2 OPTIONAL (Enumeration) MapLink (will only affect the SINGLE_LAYER rasterization type): BUILDINGS, TERRAINS, AREAS, NEIGHBORHOODS
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_rasterization/?f=HTML&token=API_TOKEN
with content:
[ 38, "GRID", "" ]
