Api session event editor overlay set key value
Revision as of 10:18, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Change a key for a specified Overlay. The Overlay must be an Overlay which makes use of keys to read attributes of geographical items, as input for its calculation. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID) |Overlay ID (must relate to a grid Overlay) | |- |1 |REQUIRED |(String) |Key name | |- |2 |REQUIRED |(String) |Attribute to look for | |} ===Response Codes=== {|class=wikitable !Response C...")
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a grid Overlay)
1 REQUIRED (String) Key name
2 REQUIRED (String) Attribute to look for
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_key_value/?f=HTML&token=API_TOKEN
with content:
[ 90, "Key name", "Attribute to look for" ]
