Api session event editor overlay set heat model
Revision as of 10:18, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Heat Model {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID) |Overlays | |- |1 |REQUIRED |(Enumeration) |HeatModel |DPRA or UNESCO |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_heat_model/?f=HTML&token=API_TOKEN with content: <p...")
0 REQUIRED (OVERLAY Integer ID) Overlays
1 REQUIRED (Enumeration) HeatModel DPRA or UNESCO
204 No Content
with content:
[ 9, "UNESCO" ]
