Api session event editor overlay set avg distance
Revision as of 10:17, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set the averaging distance for a specified AVG Overlay. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(OVERLAY Integer ID) |Overlay ID (must relate to an AVG Overlay) | |- |1 |REQUIRED |(Floating point number) |Averaging distance | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/ses...")
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to an AVG Overlay)
1 REQUIRED (Floating point number) Averaging distance
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/?f=HTML&token=API_TOKEN
with content:
[ 77, 18 ]
