Api session event editor neuralnetwork add
Revision as of 10:16, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add new Open Neural Network Exchange {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(String) |Name | |- |1 |REQUIRED |(byte or multiple values in array [a, b, c]) |Byte array content | |- |2 |REQUIRED |(String) |Uploader Name | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Neural Network ID) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com...")
0 REQUIRED (String) Name
1 REQUIRED (byte or multiple values in array [a, b, c]) Byte array content
2 REQUIRED (String) Uploader Name
200 Integer (Neural Network ID)
Example POST: https://engine.tygron.com/api/session/event/editorneuralnetwork/add/?f=HTML&token=API_TOKEN
with content:
[ "Name", [ 1, 2, 3 ], "Uploader Name" ]
