Api session event editor netload remove node
Revision as of 10:16, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove Node {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NET_LOAD Integer ID) |Net Loads | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editornetload/remove_node/?f=HTML&token=API_TOKEN with content: <pre>[ 17 ] </pre> {{article end|seealso=*api session event edit...")
0 REQUIRED (NET_LOAD Integer ID) Net Loads
204 No Content
with content:
[ 17 ]
