Api session event editor netload import net
API Event to Import Net
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | GeometryCollection | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 2 | REQUIRED | (NetType or multiple values in array [a, b, c]) | NetType[] | |
| 3 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 4 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | double[][] | |
| 5 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | GeometryCollection | |
| 6 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 7 | REQUIRED | (NetType or multiple values in array [a, b, c]) | NetType[] | |
| 8 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 9 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | double[][] | |
| 10 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | GeometryCollection | |
| 11 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 12 | REQUIRED | (NetType or multiple values in array [a, b, c]) | NetType[] | |
| 13 | REQUIRED | (TimeState or multiple values in array [a, b, c]) | TimeState[] | |
| 14 | REQUIRED | (Boolean or multiple values in array [true, false, true]) | Boolean[] | |
| 15 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 16 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Integer[] | |
| 17 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 18 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | double[][] | |
| 19 | REQUIRED | (Floating point number) | Double | |
| 20 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editornetload/import_net/?crs=3857&f=HTML&token=API_TOKEN
with content:
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799374.502164935 ], [ 658665.7023325876, 6799374.502164935 ], [ 658665.7023325876, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799418.751396003 ], [ 658694.3244829695, 6799418.751396003 ], [ 658694.3244829695, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799341.300377342 ], [ 658760.8555939179, 6799341.300377342 ], [ 658760.8555939179, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Text 1", "Text 2", "Text 3" ], [ "GAS", "SEWER", "SEWER" ], [ "Text 1", "Text 2", "Text 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], {
"geometries" : [ {
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799406.864416024 ], [ 658645.7985447575, 6799406.864416024 ], [ 658645.7985447575, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799378.536476442 ], [ 658747.5263089957, 6799378.536476442 ], [ 658747.5263089957, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799353.015104927 ], [ 658717.6016014665, 6799353.015104927 ], [ 658717.6016014665, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Text 1", "Text 2", "Text 3" ], [ "SEWER", "INTERNET", "SEWER" ], [ "Text 1", "Text 2", "Text 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], {
"geometries" : [ {
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799330.574749479 ], [ 658695.1674096022, 6799330.574749479 ], [ 658695.1674096022, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799418.434691162 ], [ 658727.2132388699, 6799418.434691162 ], [ 658727.2132388699, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799430.3086950965 ], [ 658639.1607005419, 6799430.3086950965 ], [ 658639.1607005419, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Text 1", "Text 2", "Text 3" ], [ "HEAT", "ELECTRICITY", "ELECTRICITY" ], [ "REQUEST_PLOT_OWNER_APPROVAL", "DEMOLISH_APPROVED", "REQUEST_PLOT_OWNER_APPROVAL" ], [ true, false, true ], [ "Text 1", "Text 2", "Text 3" ], [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], 64, 75 ]
