Api session event editor netload add address
Revision as of 10:16, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add Address {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NET_LOAD Integer ID or multiple values in array [1, 2, 3]) |Net Loads | |- |1 |REQUIRED |(ADDRESSE Integer ID or multiple values in array [1, 2, 3]) |Addresses | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/...")
0 REQUIRED (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) Net Loads
1 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Addresses
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetload/add_address/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]
