Api session event editor netline remove all attributes
Revision as of 10:15, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove all attributes for each specified Net Line {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NET_LINE Integer ID or multiple values in array [1, 2, 3]) |Net Line IDs | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editornetline/remove_all_attributes/?f=HTML&token...")
0 REQUIRED (NET_LINE Integer ID or multiple values in array [1, 2, 3]) Net Line IDs
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetline/remove_all_attributes/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
