Api session event editor measure set terrain height
Revision as of 10:13, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set the inner height of Terrain Spatial of a Measure. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASURE Integer ID) |Measure IDs | |- |1 |REQUIRED |(Integer number) |Terrain Spatial ID | |- |2 |REQUIRED |(Floating point number) |Height value | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: http...")
0 REQUIRED (MEASURE Integer ID) Measure IDs
1 REQUIRED (Integer number) Terrain Spatial ID
2 REQUIRED (Floating point number) Height value
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_terrain_height/?f=HTML&token=API_TOKEN
with content:
[ 57, 45, 80 ]
