Api session event editor measure import geotiffs
API Event to Import Measure GeoTIFF Collection
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | Collection of GeoTIFF Geometries where the GeoTIFF will be applied | |
| 1 | REQUIRED | (TERRAIN_TYPE Integer ID or multiple values in array [1, 2, 3]) | Terrain Type IDs | |
| 2 | REQUIRED | (Integer or multiple values in array [a, b, c]) | GeoTIFF ID arrays | |
| 3 | OPTIONAL | (MEASURE Integer ID) | Set for existing Measure ID (optional) | |
| 4 | OPTIONAL | (Floating point number) | Buffer for Points and Lines to make Polygons (optional) | |
| 5 | OPTIONAL | (SOURCE Integer ID) | Source (optional) |
| 200 | Integer (Measure ID) |
Example POST: https://engine.tygron.com/api/session/event/editormeasure/import_geotiffs/?crs=3857&f=HTML&token=API_TOKEN
with content:
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799366.211043943 ], [ 658743.4286136308, 6799366.211043943 ], [ 658743.4286136308, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799342.563936498 ], [ 658760.0045466047, 6799342.563936498 ], [ 658760.0045466047, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799416.872280778 ], [ 658677.7144431378, 6799416.872280778 ], [ 658677.7144431378, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ 1, 2, 3 ], [ [ 1, 2 ], [ 3, 4 ], [ 5, 6 ] ], "", "", "" ]
