Api session event editor measure add grid
Revision as of 10:11, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add a new Grid Spatial to a Measure. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASURE Integer ID) |Measure ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Grid Spatial ID |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editormeasure/add_grid/?f=HTML&token=API_TOKEN with content: <pre>[ 9 ] </pre> {{article end|see...")
0 REQUIRED (MEASURE Integer ID) Measure ID
200 Grid Spatial ID
with content:
[ 9 ]
