Api session event editor levee set is relative increase
Revision as of 10:11, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Is Relative Increase {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(LEVEE Integer ID) |Levees | |- |1 |REQUIRED |(true, false) |Boolean |true or false |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorlevee/set_is_relative_increase/?f=HTML&token=API_TOKEN with c...")
0 REQUIRED (LEVEE Integer ID) Levees
1 REQUIRED (true, false) Boolean true or false
204 No Content
with content:
[ 64, true ]
