Api session event editor levee remove side function
Revision as of 10:10, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove Side Function {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(LEVEE Integer ID or multiple values in array [1, 2, 3]) |Levees | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorlevee/remove_side_function/?f=HTML&token=API_TOKEN with content: <pre>[ [ 1, 2,...")
0 REQUIRED (LEVEE Integer ID or multiple values in array [1, 2, 3]) Levees
204 No Content
with content:
[ [ 1, 2, 3 ] ]
