Api session event editor indicator export debug excel
Revision as of 10:10, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Export Debug Excel {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(INDICATOR Integer ID) |Indicators | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |byte[] (byte array) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorindicator/export_debug_excel/?f=HTML&token=API_TOKEN with content: <pre>[ 87 ] </pre> {{article end|seeals...")
0 REQUIRED (INDICATOR Integer ID) Indicators
200 byte[] (byte array)
with content:
[ 87 ]
