Api session event editor indicator set active
Revision as of 10:09, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Indicator active {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(INDICATOR Integer ID or multiple values in array [1, 2, 3]) |Indicators | |- |1 |REQUIRED |(Boolean or multiple values in array [true, false, true]) |Boolean[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/sessi...")
0 REQUIRED (INDICATOR Integer ID or multiple values in array [1, 2, 3]) Indicators
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Boolean[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_active/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ] ]
