Api session event editor global set start value
Revision as of 10:09, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Start Value {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GLOBAL Integer ID or multiple values in array [1, 2, 3]) |Globals | |- |1 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) |double[][] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Exampl...")
0 REQUIRED (GLOBAL Integer ID or multiple values in array [1, 2, 3]) Globals
1 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) double[][]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorglobal/set_start_value/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]
