Api session event editor global set query timing
Revision as of 10:09, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Query Timing {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GLOBAL Integer ID or multiple values in array [1, 2, 3]) |Globals | |- |1 |REQUIRED |(Timing or multiple values in array [a, b, c]) |Timing[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorglobal/set_...")
0 REQUIRED (GLOBAL Integer ID or multiple values in array [1, 2, 3]) Globals
1 REQUIRED (Timing or multiple values in array [a, b, c]) Timing[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorglobal/set_query_timing/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "AFTER", "BEFORE", "AFTER" ] ]
