Api session event editor geotiff export
Revision as of 10:09, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Export GeoTIFF. For files larger than 2GB, use the Stream API. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GEO_TIFF Integer ID) |GeoTIFF ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |byte[] (byte array) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorgeotiff/export/?f=HTML&token=API_TOKEN with content: <pre>[ 22 ] </...")
0 REQUIRED (GEO_TIFF Integer ID) GeoTIFF ID
200 byte[] (byte array)
with content:
[ 22 ]
